820-3476 Liquid damage, no green light
hambook
Hi all, I have an 820-3476 on the bench that came in with quite a bit of liquid damage. Took these photos before putting the board through an ultrasonic cleaner with sweepable frequency as per Louis's videos and dried it overnight. It's now pulling 7mA from the power supply. So far I've followed power from the charger and found that power gets all the way to U7090 and PP3V42_G3H is present with 3.42v just past this chip. I checked 3 more spots of PP3V42_G3H across the board and I got 3.42v at each spot. Seeing as there isn't a magsafe light and there is PP3V42_G3H I'm a little confused of what I should check next.
hambook
There were a couple rusted probe points and some corrosion, used alcohol + toothbrush and worked a lot of it away and then got the following from U5110:
1) 3.4v
3) 3.4v
4) 0v
5) 0v
6) 3v
7) 3.3v
8) 0.2v
hambook
Replaced C5101, no change. Just changed U5110 from donor board, all voltages are the same and still no green light. I tried plugging in the board after removing the old U5110 but before putting the new one on and I did get green light.
Pin 4 should rise above 2.1V normally.
C5101 set the correct timing for SMC_RESET_L.
Probably more corrosion on U5110 pads/traces.
