820-3476 No backlight, missing BKLT_EN_R
nickalith
Hello!
Somewhat new to this and just trying to get some direction.
MacBook turns on, can use with external monitor, confirmed no backlight/can see an image when I use a flashlight.
I have 0V on PPVOUT_S0_LCDBKLT
Missing the enable signal for U7700. I checked where it gets the signal from and it looks like it's an OR gate, and needs either: EDP_BKLT_EN or LCD_PSR_EN to generate the enable. Both are missing. Both signals come from the SMC (I think). Anything I can do?
Check diode mode to ground at PPVOUT_S0_LCDBKLT , w/ and w/o LCD connected.
If image is present, display is correctly recognized and EDP_PANEL_PWR is present.
The other two input signals of U8330 come from CPU.
You should check their level in the first seconds (for pulse at least), when hear the chime.
nickalith
Thanks!
Diode mode showed an Open Line for PPVOUT_S0_LCDBKLT when the connector was connected and disconnected (tested with ONLY the connector inserted, no other cables or power was connected to the board when I tested). I should have mentioned I tested the same thing earlier with resistance mode and confirmed it was not a bad cable/display.
EDP_BKLT_EN and LCD_PSR_EN both pulse at about 1 or 2 mV very briefly when I supply power before going down to 0V (had only the power supply connected, nothing else) You mention that I should check for the pulse when I hear the chime, I feel like that entails that I need to have more than just the power supply connected (like the speakers, at least) for this particular test, but I'm not sure so I figured I'd include that information
No need to connect speakers.
Was only a time pointer; need to check in the first 5-10s.
Of course, internal LCD MUST be connected.
Do not waste time searching for mV pulse; there is no pulse if you cannot catch more than 1V peak.
An o-scope can show you peak value for any fast pulse.
nickalith
After plugging in the display, I actually AM getting my 3.42V on EDP_BKLT_EN. U7700 has its enable on pin 17, and is getting its required 5V on both pins 5 and 18. However, I am still getting 12V to Q7700 on the LCDBKLT_EN_L. Replace U7700?
So your first post was without LCD connected???
Very strange, as you said to have image on internal LCD; at least is what I understood.
Enable signal is not sufficient.
Backlight level is controlled through I2C bus.
Check R7750-53 resistors.
Also post diode mode and voltage on SCL/SDA lines.
I recommend you to test known good LCD assembly: as I2C bus comes from display.
nickalith
Yeah I explained it in a confusing way. I tested the computer for no backlight with everything connected, and confirmed the issue was no backlight. Then I took the board out of the macbook and started testing, not realizing the display needed to be connected (cuz I'm a dummy). Then I connected the display and found out I was getting the enable. I don't have an extra LCD assembly, if we can confirm its a bad LCD I'll probably just move on, no biggie.
R7750 = 0.2 Ohms
R7751 = 0.2 Ohms
R7752 = 0.801K
R7753 = 0.801K
both R7752/3 are supposed to be 2.4K per the schematic?
Diode Mode (no power to board while testing these)
BKLT_SCL = 1.63V
BKLT_SDA = 1.63V
Voltages
BKLT_SCL = 5.039V
BKLT_SDA = 5.039V
The resistors usually show lower values when measured onboard.
Check always diode mode with red probe at ground.
And forget the "V" when post the values.
Do PRAM reset 2-3 times, just in case.
A known good LCD assembly is the best test.
You can waste time in a board without problems, just bad LCD.
