820-3476 No power
BCN_Techs
The macbook entered wet and with sulfate in this area:
It has been cleaned, I replace the components and now there is no chime: green - orange led, cpu heats up and there is usb activity.
PPBUS_G3H = 12.57V
PPDCIN_G3H_ISOL = 20.30V
PPDCIN_G3H = 20.30V
PP3V42_G3H = 3.43V
PPVRTC_G3H = 3.33V
PP5V_S5 = 5.15V
PP5V_S4 = 5.15V
PP5V_S0 = 5.15V
PP3V3_S5 = 3.33V
PP3V3_S4 = 3.33V
PP3V3_SUS = 3.33V
PP3V3_S3 = 3.33V
PP3V3_S0 = 3.33V
PP5V_S0_FET = 5.15V
PP3V3_S0_FET = 3.33V
PP1V05_SUS = 1.06V
VCORE = 1.70V
Thanks.
If you have USB activity for sure, do PRAM reset.
This should bring chime back.
Did you test external video?
Do you get 5V at pins 28-30 of J8300, in the first few seconds at least?
LCD_HPD_CONN and DP_INT_HPD should go high at same time.
BCN_Techs
PRAM RESET but still the same.
No signal on external monitor.
LCD_HPD_CONN = 0V
DP_INT_HPD = 0V
In power supply, the current goes from 0.02V up to 0.95A directly.
USB power is not the same as USB activity!!!
Your board can't have activity, if PLT_RESET_L stays low.
I wouldn't ask you for external video, or PRAM reset, if you didn't say to have USB activity.
Check pins 7 & 3 of U1950.
