I'm working on 820-3476 which came for no power. It had some slight corrosion on JTAG, around R7202, U7600, some on C3201 area and really small stain on U6100. I have removed JTAG, cleaned eveything, replaced damaged resistors, caps, resoldered chips (U6100 too). Computer turns on, works on battery and on the charger. Problem is, that SOMETIMES when I turn it off it will not turn on from power button. I have to reconnect battery, then it starts working again for some time. It olny happens when battery is conected. When on charger power button works every time. I have tried new keyboard, new battery and even replaced SMC with new one. Sadly there is no differenece... Diagnostisc shows no errors, when computer is on it works perfectly fine..
