820-3476 pulsing. not turning on
donnos
Hello,
I have an 820-3476 that initially had short on ppvcc_s0_CPU. removed the damaged cap C1008 near the cpu without heat.
no more shorts but still does not boot.
i detected pulsing voltage when plugin in magsafe from s4 all the way to all_sys_pwgd. no other shorts found so far.
any suggestions on troubleshooting steps to continue ?
donnos
resistace to gnd on L7310/20 is 42ohms
only liquid signs on c1801(removed) and Q1840(replaced)
and yes stable 3v3_s5/SUS.
donnos
can't find PLT_RST_L, hopefully PLT_RST_BUF_L is the same.. and no pulse here
and nothing on pin 3 of u1950 either
donnos
***you can ignore this***
i'm measuring pp3v3_S0 @ 1.9V. is this right? i'm not even getting p3v3s0_EN always on how is there even voltage here @@?
Yeah, is PLT_RESET_L in fact.
Check for pulse at pins 7, 5, 6, 3 of U1950.
Inspect its area for corrosion.
Check all SPI Bus Termination resistors and traces.
Clean J6100; remove, if needed.
You should have something more corroded.
Also possible to have accumulated crap underneath SMC, or CPU.
donnos
all SPI termination resisters and traces are in order.. no other corrosion seen from the original c1801(removed) and Q1840(replaced).
J6100 is removed and SMC already reballed. which only left CPU. dead CPU or just reflow?
