820-3476 shift keys dont work
Gannons3
All other keys but the shift keys work, I replaced the keyboard but they still do not work, computer was liquid damaged
smiba
Does both the left and right shift not work?
Anyways inspect keyboard connector for corrosion and check continuity for all WS_KBD signals to the U4801 chip
Already tried booting into a OS from USB to verify its not a software issue? (Pro tip: In ASD OS there is a keyboard test)
smiba
My bad, 820-3476 is the macbook pro 13" late 2013 right? Apple uses ASD2 for that which is not available for unauthorized stores :(
So like I said check the connector and WS_KBD signals. If thats all looking alright boot into something like Internet Recovery and see if you can use the shift key in there. Otherwise U4801 might be damaged but this pretty much never happens
Gannons3
also forgot to mention that I had the customer try to do an smc reset just to see if it would work outside the os. and it didnt work
Left shift and right shift are 2 completely different things. Right shift is part of the keyboard matrix along with all the other keys. Left shift is part of the SMC reset circuit. It seems unlikely both keys are not working.
Gannons3
customer claims both shift keys arent working, ive yet to get the computer back though, ill update when i get it
Pin 1 2 and 3 should come high when the corresponding key is pressed. Usually corroded pin inside the connector or bad keyboard.
