820-3536 no image, got chime and fan spin
ajdoc
Liquid damage board around J8300
J8300 replaced as pin 3 was burned out.
Got chime, fans spin, USB light but no image.
PP5VR3V3_SW_LCD got 5V
LCD_HPD_CONN got
Resistors around U8340 and U8340 are OK.
Any idea?
ajdoc
No video on ext display - those DP ports are not looking good :(
U7700/1 0.25V
U7700/2 0.25V
U7700/4 0V
U7700/5 5.13V
U7700/6 5.12V
U7700/8 5.10V
U7700/9 12.59V
U7700/10 12.59V
U7700/11 12.16V
U7700/12 0V
U7700/13 1.12V
U7700/14 jumping from 0.75V-1.75V
U7700/15 5.12V
U7700/16 5.13V
U7700/17 0V
U7700/18 5.13V
U7700/19 1.75V
U7700/20 1.19V
U7700/21 jumping from 0.20V-0.58V
U8330/1 0V
U8330/2 0V
U8330/3 0V
U8330/5 0V
U8330/6 0V
U8330/7 0V
U8330/8 3.33V
"U7700/17 0V"
Missing enable signal for backlight.
"PP5VR3V3_SW_LCD got 5V
U8330/3 0V"
This is not possible, unless U8300 is shorted.
EDP_PANEL_PWR_OR_PSR_EN is required to enable 5V on pins 28-30 of J8300!!!
If you checked these voltages without LCD connected, NOT good.
Check all again; less keyboard backlight signals/voltages (not needed).
ajdoc
I replaced U8300 had back 3.33V on pin 3.
Tested with another display and had image but no backlight.
J8300/1 0V.
J8300/10 3.33V
J8300//30 5V
The issue was with two traces on J8300/3 and J8300/4. Both Had 0V. Jumpers from other side of the board.
5V was back on both pins and got backlight.
Maaany thanks guys for tips :)
