820 3536, Not charging with original charger
Noguinfor
Hey,
this one is the second time it comes back!!!
First time the problem was C7376 shorted i replace the capacitor and realize the machine only work's with my fake charger! I replace the Q7180 2 times no changes, only works after to replace r7012.
After 2 weeks this one comes back with same problem!
It has happened to me many times, i repair many machines with a shorted cap or some times corrosion on simple component and after repair the main problem next the machine don't charge with a fake charge!
This one is giving me a headache!
"820 3536, Not charging with original charger
the machine don't charge with a fake charge!"
More clearly possible???
Do you get PPBUS_G3H and 3V42 with original charger?
What about with fake one, or bench power supply?
Did you check D7012?
Noguinfor
I'm sorry for my mistake! i want to say original charger on "the machine don't charge with a fake charge!"!
But on this moment for me complicated more because i disassembly the macbook and the motherboard start to work with original charger!!
I did not want to send it back to the client and 1 week later comes again! this is inconstant! do you have any advice so do not come back to it ?? thanks
Noguinfor
Okay, to avoid mistakes:
Original Charger - without battery plugged the machines start well
- with battery plugged i don't have green light and machines don't work
Fake charger - with/without battery plugged the machines start well but don't charge the battery
i can see 4% on battery i think it's not a battery problem.
The machine starts on battery only?
Connect both charger and battery.
Then post U7100 voltage pins 9 & 15.
Check resistance between pins 17/18 and 27/28.
Also try to start in SMC bypass mode.
Noguinfor
I was wrong again! I forgot that I can only see if it is charging when I enter to the OSX! Small change:
Fake charger - with/without battery plugged the machines start well and charge the battery
Noguinfor
U7100 voltage pins 9 & 15 - 0V & 0.066V
resistance between pins 17/18 and 27/28 - 6.3ohm & 23.6ohm
already tried to do reset SMC with BATTERY and Charger and the machine start but don't have green_ light! only assume battery!
i don't know if help but i remember when it comes for the first time i needed to replace DC-IN (820-3584) for another one!
tha nks
MLB should start without LIO flrx connected, just the 5 pins DC cable required.
Post voltages for U7100 with original charger only; 2, 3, 12, 13, 14, 17, 19, 20, 27.
Noguinfor
U7100
pin2 - 16.63V
pin3 - 4.09V
pin12 - 3.4V
pin13 - 3.4V
pin14 - 3.4V
pin17 - 12.61V
pin19 - 5.5V
pin20 - 5.5V
pin27 - 17V
Noguinfor
on this i replace U7100 and now it's charging! i'm with a little afraid to send this to the client and come back again!
