820-3662 no chime
Kyle93
Arrived with no liquid damage. Turns on with fan spin but nothing else happens. USB mouse light comes on.
L7310 1.790v
L7320 1.795V
L7330 1.807V
Should all three FDMF6808N chips be replaced?
If board doesn't boot at all, I doubt it will revive changing these chips.
Can you confirm USB activity for sure?
Use macOS installed on pendrive with Link LED; if flashes, is OK 100%.
Also do PRAM reset 2-3 times, if possible.
"PLT_RESET_L 1.3V "
Reset must be disabled, 3V is required there.
PCH doesn't finish power on sequence correctly.
Check PM_SYSRST_L, PM_PCH_PWROK and PM_PCH_SYS_PWROK.
"PM_SYSRST_L 3.3v "
Then was a misstyping previous post?
Check all SPI Bus Series Termination resistors and their traces,
Clean J6199; or/and remove it if you don't use Medusa.
Try known good BIOS...
