820-3787 Cycling
bjf
Can't figure this one out. CPU power is going up to normal every time. Y1905 voltage is also going up to normal every cycle. ALL_SYS_PWRGD cycling to normal too. All voltages cycle up to normal. U1950 is good. Board was barely hit by liquid. I attached pre-cleaning pics. Not much there at all. No shorts that I have found. Vcore is at 14Ω to ground. Checked all SPI resistors and traces. Not sure where to look next.
bjf
There is barely any sign it was spilled on. The only thing I could find was on the 5V_S4 line on J9510 and C9511. Measuring fine though. I was concerned U5823 might have been hit but it looks good and the voltages are measuring normally also. All the voltages cycle every 3 seconds or so and it's just an up and then right back down thing, so maybe 1 second at most.
Yeah this one will suck. All I can say is inspect closer for corrosion. CPU may have died as is so common on these.
