820 3787 - Don't turn on - Green light
Noguinfor
Hey guys,
this one came with no green light and with battery the machine turn one! Using my DC power suplply i noticed the U7100 a little hot. Replace the isl and green light appear!
Now i have 3.7V o PPBUS! Already replace 2 times the ISL for a new one! and i need to replace R7151 and R7152.
i have 4.9ohm on c7150 and 22.8ohm on c7150.
I don't want to touch in other components without certainties!
any advice are welcome!
thanks
Did you try SMC bypass?
Are you using original 85W charger for sure?
Post some voltages for U7100; pins 1, 2, 3, 12, 13, 9, 15, 19, 20, 26, 27.
Noguinfor
Yes i'm using a original Charger 85W. And not start in SMC byass!
U7100:
pin1 - 0V
pin2 - 16.41V
pin3 - 3.89V
pin12 - 3.42V
pin13 - 3.39V
pin9 - 0.03V
pin15 - 0.054V
pin19 - 5.52V
pin20 - 5.53V
pin26 - 14.74V
pin27 - 20.14V
On battery only, OSX recognizes battery percentage?
"pin26 - 14.74V"
Too low for 85W charger.
Be sure all R7120-22 are good.
If charger is really 85W, then change Q7180.
Noguinfor
Ok it's Working!
This one ended my resistors 10ohm off my pile!
Needed to replace the resistors + u7100 + Q780 at once!
Solved! Ty Mr.Vali one more time
