820-3787a no backlight image can be seen liquid damaged.
PCTRONICS
Gday guys I'm using schematics for 820-3332 so hope layout is similar. unit has corrosion on c8513 PP1V5R1V35_S0GPU would this cause no backlight? because I wouldn't think so unless this rail must be complete before backlight shows up. or is it as simple as replace backlight driver? I'm getting 0.560 Diode on L9000. I'm not 100% familiar with this retina model so any help would be great. I'm getting 12v on both sides of the fuse.
Check diode mode to ground at pin 1/J8300 w/ and w/ LCD connected; no power applied, of course.
Also check if F7700 is OK.
Post voltages for Q7706 and U7701, pins 5, 18, 17, 11; LCD connected this time.
Be sure to have continuity from U7701 to R7708/09.
PCTRONICS
R7708/09 have cont. R7709 is 16K it should be 150K is this the feedback?
F7700 is fine
J8300 P1 with lcd on is 0.033 Diode mode
J8300 P1 w/o lcd is 1.149 Diode mode
Q7706 P1 -0.060 P2 -0.060 P3 12V P4 12,3V P5 0.060 P6 0.060
Hope this helps
Check R7743/44.
Be sure no short on pins 5 & 18 of U7701, if you need to replace them.
Check first if =PP5V_S0_BKLTCTRL arrives to R7743/44...
PCTRONICS
Im getting 5v on both those resistors R7743/4 both 2.5Ohms and both are 0.374 in diode mode
JohnB8812
There is nothing wrong with the driver you said you have 0.003 with the screen connected but it 1.1 without. Replace the blown fuse and measure again with a KNOWN GOOD screen
"J8300 P1 with lcd on is 0.033 Diode mode
J8300 P1 w/o lcd is 1.149 Diode mode"
Ooops, I didn't read this full.
You have LCD assemblw problem; video cable, or display itself (more probably).
But confirm again all measurments, because you posted 0V on pins 5 & 18 of U7701 first time and 5V next post.
Always measure voltages with LCD connected.
Please provide accurate information.
PCTRONICS
What fuse?. i said i had 12v on both sides. the fuse F7700 is fine unless you are referring to another one. ill try another screen.
PCTRONICS
My apologies i measured U7701 with the machine off. the second measurement was with machine on. thanks am getting a screen now. will update in the next hour. both pins 5 and 18 are getting 5v.
