820-4924-A (Retina 2015) Running Slow
rkrishnan
Hey,
I got an 820-4924-A motherboard with possibly some liquid damage and just did a Bios ME Region clean (since it had an EFI lock in it). Battery charges and it runs off battery so I was happy, but now I am running into a new issue.
The system is running very slow and kernel_task is using up majority of the CPU. When I run ASD it gives the codes PFM006, and PPN001. I installed iStat and found the Left Fin Stack sensor and air flow proximity sensor area reading as empty.
Could you please point me what I should check for? I am out of ideas on what to test since ASD isn't giving useful information. I already checked I2C_CPUTHMSNS_SDA and I2C_CPUTHMSNS_SCL don't have a short to ground, and PP3V3_S0_CPUTHMSNS_R is getting 3.3v.
I also can't find where the Th1H sensor is located on the motherboard with the schematic.
Thanks!
rkrishnan
Sorry I meant I cleared the part part between the $SVS tags, I thought that was the ME region. I didn't touch anything else.
rkrishnan
Fixed! One of the resistors (R5875) near the right fin stack on the schematic was loose and fell off. Soldered it back on and it works again :)
