820-4924-a running slow
TBFix
Hi yes Pram and smc rests done. Changed those components but still the same very laggy in OS and progress bar. Still getting the "Heatpipe outgoing air 129c"
The problem should be U5870 related.
Did you check all surrounding resistors and caps?
See what happens removing Q5871.
Check around U5850 too, just in case.
TBFix
U5850 is not on this board around the area looks ok. I checked caps and resistors and traces around U5870 no issues. I removed Q5871 and it runs even slower to a crawl.
I swapped the SMC in case it was having an issue but still the same.
