820-4924 Green led 5 sec and shut down
raainxx
i have this board, i have a green led with an original 85W magsafe2, the green led shutdown after 5 sec and come back after some seconds.
With a PSU, the led stay green and become orange. No liquid damage, the customer put a bad power supply on this mac.
i can't verify voltage with the original pw adapter.
i find a bad R7105 40K instead of 20ohm, i change it but same problem.
The mac work on battery charged.
I don't know where i check, can you help me please?
thanks
Usually leakage on Q7180, or Q7010.
Post Q7010 voltages with original charger.
Also post exact ohm value for R7012, measured onboard.
Check D7010 if short, or open.
raainxx
R7012= 5,6Kohm
pin 5-6= 17V but not stay.
pin 1-2-3=17 but not stay
i change Q7180 & Q7010? R7012 too?
D7010 seems good (0,78V & 0L other way).
raainxx
ok i try tomorrow to change it and i tell you after.
i don't understand and you can explain me, why the original charger stop to send the power? the mac talk with the charger?
Because original charger is "smart" enough.
It has an embedded processor, which first needs to properly detect the expected board!
raainxx
hi 2informaticos, I change Q7180 and R7012 became at 68K.
The green led stay with original charger, repair done, thanks a lot.
