820-4924 liqued damage 18volt on pp3v42
Repairable
Hi all,
so got this puppy in from a repair shop they seem to have cleaned it.
wel around U7090 there was some water.
after replacing the ic and caps around it that had damage,
nice stable pp3v42
but nothing for the rest.
no pm_slp_s4_l
no vcore
no S4 lines
psirom looks good
could the 18volt on pp3v42 killed the board?
Yes starts green turns orange
ppbus-g3h 12,60v
smc-lid 3,3volt (memory not at shop atm)
smc-reset-l present 3,3v
SMC_ONOFF_L 3.3v
Check the usual, U6100 termination resistors/traces. Clock chip area, 3V to RTC. If there really was 18V on 3V42 the SMC would be dead, but it seems fine.
u6100 ternimation resistors measure good and traces look good also the coper points are pretty and nice round
PCH_CLK32K_RTCX1 32.68mhz on osciliscope but jumping up and down from 32.86mhz to 32.89mhz (0.395volt i dont know if this is even needed please tell me if it is i think the mhz is the needed)
PPVRTC_G3h 3.392volt
spi_rom
pp3v3_sus 3.327v
SPI_MLB_IO0_MOSI 3.327v
SPI_MLB_IO1_MISO 3.327v
SPI MLBROM CS L 3.327v
SPI_MLB_IO2_WP_L 3.327v
SPI_MLB_IO3_HOLD_L 3.327v
PP5V_S5 diode0.441 15.04kohm 5.02volt stable 2 spots measured
PP5V_S4 diode0.547 9.29 mohm 0 volt no spike when pluged in
PP5V_S3 diode0.401 14.01kohm
PP5V_S0 diode0.401 14.07kohm
p5vs4_en diode0.539 102.8kohm 0.000volt
u8060
pin 1 + 3 5,02 volt
pin 2 0.000volt
pin 6+7 0.000volt
P5VS4_EN_D 0.000volt
s4_pwr_en diode 0.426 73.1kohm 0.000volt
S4_PWR_EN comes from PM_SLP_S5_L if i read back correct
PM_SLP_S5_L diode0.426 73.6kohm 0.000volt
yes it does Duke, turns on with known good battery.
it also charges, booted to os and checked went up from 70% to 100% no issues.
charger connected ppbus_g3h 12.85V
only battery ppbus_g3h 12.57v
wont turn on with only charger ppbus_g3h 12.59v
oke, this is fun.
when I insert a SSD (know working)
it boots fine, fan spins no issues charges etc.
when I insert the original SSD.
it wont boot unless I press the power button, the SSD is not recognized.
no fan spin.
not working SSD
when I then measure
PCIE_CLK100M_SSD_P 0.245 diode
PCIE_CLK100M_SSD_N 0.245 diode
Working SSD
when I measure
PCIE_CLK100M_SSD_P 0.030 diode
PCIE_CLK100M_SSD_N 0.030 diode
this is the only difference I could find.
hints are welkom
