rany
MBP 13" Retina 820-4924 "died suddenly" as per owner. They tried "resetting" without success (not sure what they did).
No liquid damage. No prior repair apparent except local AASP diagnosed "bad board." They removed the board at some time (missing screws).
They may have caused something in the process, since I found couple of resistors with pry damage near SMC (may have caused them myself tbh).
Using 85W original charger and 2 previously tested panels, noticed it was "no backlight."
PPVOUT_S0_LCDBKLT is 48.9V @ connector.
LCD_HPD_CONN is 2.5V @ connector.
PP5VR3V3_SW_LCD is 5.1V @ connector.
EDP_BKLT_PWM is 0.225V @ connector => 1.8M Ohm resistance to GND =>SMC_LID is 3.39V on R5171 near SMC and EDP_BKTL_EN is 3.335V @ R1430.
Is there a feedback for this circuit that I need to worry about?
What could be causing PWM to be so low?
Can I inject PWM to connector or may harm CPU?
Any suggestion as what to do next is welcome. Thank you!
