Jay
By following the schematic best I could and with the help of two other posts on this forum:
- https://www.rossmanngroup.com/board...leshooting/19199-solved-820-4924-no-backlight
- https://www.rossmanngroup.com/board...leshooting/24554-solved-820-4924-no-backlight
I am stuck.
Unit POSTs, loads the OS (visible with flashlight) and passes all but one hardware test. Hardware test shows "there may be an issue with the display". Thanks Apple, helpful!
+ Tested with good 2015 display, also no backlight.
+ Measurements are taken with display connected and lid open.
+ I suspect minor liquid damage (small trace on bottom case) but board is clean, like new clean.
(Sorry, these are not in order, I kinda jumped all over the place)
R1430 = 3.34V
R8331 = 3.34V
U7700 = 3.34V pin 17 // 0V pin 2
Q7701 = 023.1mv slowly rising pin 5 // 0V all other pins
R7742 = 3.34V pin 2
PPVOUT_S0_LCDBKLT = 007.1mv on D7710, C7760-65, C8300, C8303 (these should read 53V correct?)
L7710 = 020.4mv slowly rising
Q7700 = 12.44V pin 3 // 12.6V pin 4 // 020.1 slowly rising all other pins
F7700 = 12.6V both pins
PPBUS_G3H = 12.6V
R5171 = 3.4V (SMC_LID)
J8300 = 008.2mv pin 1 // 5.1V pin 30 (connector looks good, all pins connected)
C7700 = 12.6V
R7701 = 12.6V
R7731/32 = 007.1mv with very slight variations up and down.
Any help appreciated
I am stuck.
R1430 = 3.34V
R8331 = 3.34V
R7742 = 3.34V pin 2
PPBUS_G3H = 12.6V
C7700 = 12.6V
R7701 = 12.6V
