820-4924 No CPU Vcore
bighead
I received this board. It was liquid damaged
I don't know where exactly, because it was cleaned before I received it.
Corrosion:
Around LVDS
KB backlight connector
J6100 - I removed it
U7200 - some corrosion next to it.
I cleaned the board.
The board goes to S0 state, but CPU Vcore does not present.
Missing CPU_VR_EN.
PPVMEMIO_S0_CPU 1.205V
PP1V05_S0 is present.
ALL_SYS_PWRGD - 3.3V
Y1905 - oscillates
L7630 - 1.05V
PCH slowly gets warm
U7200 powers on as far there are PP5V_S0 and PPVIN_S0_CPUVR_VIN.
Should I just change U7200 or is there something I'm missing?
Thank you.
Hmm, that does mean that CPU_VR_ON must be there or there must have been a pulse there. R7201/2 and traces are suspect
bighead
I rechecked R7201/2 and everything looks fine there. I've the right voltages on them.
I checked CPU_VR_EN if there is any pulse on that line, but nothing at all.
Checked the resistance on VR_ON again and it's open, so there is no short.
I'm trying to figure out what needs to get that signal.
Looks like it comes from the CPU.
ALL_SYS_PWRGD high and PM_PCH_SYS_PWROK is also present. Is that possible that trace damaged?
I checked R1955 also. No pulses on it.
It could be anything. The CPU needs to be alive to enable the VR_ON. Could be dead CPU or corrosion under SMC/CPU.
It could be U7200 but it would be my last suspect.
