820-4924 - no image or back-light
nelo1012
have a 820-4924 and had very minor liquid on u 8300 and mostly on C8352 pin 2,
is this a GPU issue, i seen it pin 2 of C8352 goes to the GPU,
There is no dedicated GPU.
Mentioned line goes to CPU.
Do you get chime and USB activity?
Check if you get voltage on L8300; there must be 5V in the first 1-2s, even without LCD connected.
"DP_INT_HPD 0.0v"
PCH cannot detect the LCD in this case.
You must check this signal when 5V is present at L8300.
Try known good LCD assembly; be aware of year compatibility.
nelo1012
i checked DP_INT_HPD while a known working display connected and also known year to be compatible.
also yes, i checked L8300 having 5v while testing DP_INT_HPD
