820-4924 No power J4002 has history
prodigy83
Board 820-4924 is back, the issue before was the computer ran super slow, that is until you guys told me to remove pins 9/8 on J4002 (camera sensor issue). This did fix that problem, but now the board is back for not powering on.
C7500 on pin 1 is 12.57v
I could be wrong, but isn't it supposed to be 8.6v?
I have been checking all over and I seem to have S5 5v rails, until I get to 5v S4 rails no voltage at all.
What should I try to do next? Thank you!
PPBUS_G3H depends of R7112 position.
It is connected according with battery type.
Compare 4924 with 00165 schematic, for example; is R7113 in last case.
The level on CELL pin of ISL6259 decides the output voltage.
Did you test the board alone on the desk?
Be sure to use 60/85W Magsafe 2 charger.
Do you get amber light at least?
3V3_SUS comes on?
prodigy83
Yes, I plug it in and it goes from green to amber like normal without the battery. I have been using the 60watt MagSafe 2, I have not tried the 85w. Yes I have been testing the board alone. I have been able to reset the SMC. I will check out the other things and post my findings on those, thank you.
prodigy83
Okay, new development. When I tried with the 85w MagSafe, it actually came on. I am having problems now though with the keyboard and trackpad not working. Also the battery is charged up, but the computer will only power on with the Magsafe. I can now use the 60w Magsafe now every time.
I do have a new keyboard and trackpad cable. I replaced both of these, and this did not work. The power button does work because I am able to power off the computer holding it down for several seconds. When I tested the trackpad and keyboard on another palm rest I had in stock with the keyboard and mouse, the external display was not sending any kind of signal through the mini display port. So external video is not working, but I hear it doing the chime. I then tested with an external keyboard and mouse, and both of these work (boots up to the customers name/login screen). I am thinking this is all relating back to a sensor issue? A bit more history on this Mac, and it originally had a lot of heat damage inside, meaning a lot of the parts that I would normally unplug, some had cracked or broke (plastic) from the heat over the years, which I had to replace, even the keyboard was replaced. Why the problem with the computer not turning on from the battery, and trackpad/keyboard is not working? Am I not getting enough power from something?
Machine boots with charger and battery connected?
Just doesn't turn on from battery alone?
Check PPBUS_G3H and 3V42_G3H in last case.
Do you get image internal/external only if trackpad flex is not connected?
In such case, check SMC_LID signal.
prodigy83
Correct, battery must be connected or it won't turn on.
Correct.
I get both of these with no problem.
The trackpad cable makes no difference if it is plugged in or not, so no change.
I just did a bit more troubleshooting, and the external video does work fine, I placed the motherboard in with our donor screen and keyboard/trackpad/palmrest and found the computer kept booting in to the password reset screen. After I got it out of there, and logged in as a guest, I got picture from the HDMI port, but not until I was fully logged in as a guest.
This is at 3.4v. To add from some additional testing last night, I found the following to pulse:
U7100 on pin 16 fluctuates from 5.24 to 12.53, then 5.24 to 12.53 again, and it keeps doing this.
If internal LCD is disconnetced, do you get external video from the start?
When just battery is connected, trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (at same time).
PM_RSMRST_L should go high then.
prodigy83
From the start with the external display? No.
I apologize for my ignorance, but I read your article on this located here: https://boards.rossmanngroup.com/threads/how-to-collection.60974/
and I am just a little confused. You said to touch any metal plate. Does this mean I can take any SMC_ONOFF_L line, and solder a wire on to one of these, in my case I have soldered on to R4810 pin 1, and touch ground on the motherboard?
prodigy83
I got it working, thank you very much. I ended up replacing U8000, and I looked at the trackpad connector on the motherboard, and the metal contacts on the exterior of the connector, the plastic ended up needing to be scraped away with tweezers. After this, I hooked it all back up and it was all working. Thank you so very much!! :)
