820-4924 no PPBUS_G3H
Sr. Robot
PPBUS_G3H is 0.5v, diode mode to ground is 0.113.
removed F7140, PPBUS_G3H is 0v. Removed L7130 still no PPBUS_G3H
PP3V42_G3H diode mode is 0.256
U7100 basic voltages (F1740 and L7130 removed)
1 = 0v
2 = 16.5v
3 = 4v
9 = 0v
12= 0v
13 = 0v
14 = 0v
15 = 0v
17 = 0v
19 = 5.5v
20 = 5.5v
27 = 16.2v
Sr. Robot
R7020 measures good. D7005 was odd looking and replaced it just in case. Now i get the same voltages but PPDCIN_G3H is more stable (only pulsing for about 0.1v).
Q7010 and U7090voltages remain the same
Sr. Robot
But now the battery is not charging.
Tried good battery, no change.
If battery is connected it tas a while for green light to come on, some times i have to reconnect it several times for light to come up.
After boot, if i disconnect the charger, the laptop goes to sleep. Battery not detected by OS (no battery icon or system info)
PPBUS_G3H is 12.2v (without battery), 12.2v (with both charger and battery), and 11.78 with only battery.
SCL and SDA diode mode to ground is 0.453
CHGR_A/BMON are 0v with and without battery connected.
battery bus voltages:
w/battery:
SCL: 0.9v
SDA: pulsing to 3.4v
w/o battery: same behaviour
Pins 17/18 of U7100 is 3.9 ohms. 27/28 is 20.1 ohms
