820-4924 no video or backlight
ytesfay80
This board was liquid damaged around the lcd connector area and the bottom side of the board by the lcd connector. I have replaced the lcd connector, lcd cable and the following components.
L8300, C8300/03, C8359, I also replaced a component also in that area(image attached) but I don't know what the component is for because i don't have a boardview for for 4924 so I have to use the one for the 820-3536.
There are some other caps/resistors and chips that don't look too good in that area but they are for Thunderbolt so I just left them.
There was no continuity from C8300/03 to the BKLT pin 1 of J8300 so I had to run a wire to connect those lines.
When I plug in the charger and screen I feel the CPU getting warm but even after 30 seconds of it being on I see no image on the screen even with a flashlight shined on it.
I also get 3.3v on Pins 6/7 of the connector. Pin 1 for BKLT gives me 0v
Q7700 voltages:
Pin 4: 12.56v
Pin 3: 12.46v
Pins 1/2/5/6: 0.05v
SMC_LID is a steady 3.4v
R7701/02 have the proper resistance measurements
R7742 has 0v on both sides so I think that may be an issue.
The circled piece is C7778, not critical...
Did you check external video?
Is there USB activity at least?
J8300 must get voltage at pins 5, 28-30 in the first seconds.
The voltage is maintained only if DP_INT_HPD goes high; which means LCD is correctly recognized.
No backlight before that, of course.
ytesfay80
Yes I get video when with hdmi output and screen plugged in. I do get USB activity.
Sorry I forgot to list voltages for pins 5, 28-30 in the earlier post but i took them
J8300 - Pin 5: 3.32v
Pins 28-30: steady 5.12v
Check DP_INT_HPD voltage; pin4/U8340.
Confirm 3V there.
Next, check all FL8300-3 coils and all C8320-9 caps, if present and good.
ytesfay80
Yes I get 3.3v on Pin 4 of U8340.
C8320 - C8327 all get a steady 0.45v on Pin 1 and on Pin 2 it starts around .13v and slowly goes down towards 0.03v.
C8328/29 have 0v on everything except for Pin 2 of C8328 which has around .04v
FL8300-3 look fine visually and it shows around .13v and slowly goes down towards .04v as well
How should I measure if FL8300-3 is good?
C8320-29 in diode mode all measure 0.324v on Pin 1 and OL on Pin 2.
ytesfay80
Yes there is continuity on all FL8300-3 pins.
I noticed C7766/7/9,C7717, C7776 were corroded and looked dark so I replaced those but still that didn't fix the issue.
All of the J8300 pins have a good connection and there is even continuity from J8300 to the connector on the LCD. I don't have another assembly to be able to test.
When I measure Pins 1/2/5/6 of Q7700 I keep getting -0.05v. Pin 3 has 12.46v and Pin 4 has 12.56. Do you know why it's not getting the correct voltage?
Does R7742 getting 0v an issue since that is the EN pin for U7700?
If you miss image and backlight at same time, is not from U7700 area.
Post U8330 voltages.
I still suppose corrosion issue near LCD connector; maybe on the other side.
ytesfay80
Okay I ultrasonic'd the board again, replaced the lcd cable and connector again and now I see an image on the screen but no backlight.
Now on Q7700 I get 8.6v on Pin 3 and 12.56v on pins 1/2/5/6.
On pin 1 of J8300 I get around 0.78v and it slowly keeps going down.
