macRepairAmb
Have this board that doesn't power up, found
PP5V_S0_CPUVR - 1.19v
PP5V_S3 - 5.1v
isolated to both Q7310 and Q7320 to be blow, short between pins 4 and 1,2,3 pins. Resistance reading of about 2ohms. Resistance reading of just pins 1,2,3 to ground is 12ohms, which matches a good board. Replaced both Q7310 after confirm short was gone on pin4 pad's. Once power is applied, both transistors blow out again.
Everything else appears to be measure good, except this two transistors. One thing to note, the transistor package label didn't match the new ones i installed which are both
SISA12DN (new from mouser).
Any suggestions?
PP5V_S3 - 5.1v
Any suggestions?
