820-4924 not turning on
the board has orange light on the charger and these rails are present:
PPBUS_G3H
PP5V_S5
PP3V3_S5
PP3V3_SUS
but there is no sign of S3 and S4 rails
I've already checked for a short to ground on them and there is no short nor a burned or damaged prob point.
smiba
If you have a multimeter you might be able to catch this by setting it to its most sensitive DC Voltage mode, you will see it shoot up a little bit that way.
Another option is using a LED with a 500 to 1kohm resistor to the PP3V3_S4 rail (Or to PP5V_S4 with appropriate resistor so the LED doesn't burn out)
What about the other questions 2informaticos asked?
