820-4924 "P" Key not working.
Thomas
Where do I start with this? I already tried a different keyboard and confirmed the issue is on the Logic Board. Any help is very much appreciated.
Keyboard connector looks perfect, no signs of liquid damage around it.
Impossible to have only one key not working because of MLB issue.
The keyboard matrix has more keys connected on every raw and column.
Check again all the keys, you should find other non working ones; maybe special functions.
Thomas
UPDATE******
Turned out the issue was U4820. Simply reflowed it with some fresh flux and it solved the issue. There must have been some liquid under it. Originally the Logic Board was liquid damaged but showed no liquid damage near the keyboard connector. Anyways all is working perfectly.
Case closed.
Thank you much!!!!
