820-4924 - PP5V_S0/S3 Missing
pws6074
I will try to explain what happen now:
If i take the SSD and let popup the mark folder, the battery works fine.
However, if i put back the SSD and boot the OS normally with the charge plugged the system can't find the battery.
sound's weird, right?
Answer your question, i get 12.39V with and without battery on PPBUS
smiba
What do you mean with battery works but not in the OS?
Do you mean that the system will keep on running even if you remove the AC adapter, but not while in OS?
Do you mean that the system will change the battery but not if you're in the OS? (Only orange light before boot into OS)
Do you mean that the system will only report the battery being there in the boot menu?
Very unlikely that booting into the OS changes anything about the battery, at best the interface is just not working properly. (I've seen on systems with no battery connected the Filevault login screen of a encrypted system showing 100% battery, this is not true)
Check if SMBUS_SMC_5_G3_SCL/SDA is not going to ground, verify R5380/81 are up to specification.
Check voltage of SMBUS_SMC_5_G3_SCL/SDA with the battery it came with plugged in, it should not be above 3.5V as that would mean the battery is killing the chips on the datalines.
Was there a lot of crap around the SMC before you threw it in the ultrasonic? You might try a reflow before you replace it
It is just not seeing the battery. It will power on from AC and when you pull the charger it remains on. Powering on from the battery will not work.
Your SMC and/or ISL6259 are dead. SMC is the more common.
pws6074
No Title
Take a look the videos:
with OS, don't hold the battery, just with charge
without OS (SSD) i can't take the charge and the battery hold works fine.
I know, seems crazy, however, you can see on the video i just upload.
Btw: The ISL6259 is replaced
Video Link:
https://streamable.com/t2xkq
https://streamable.com/5m7uh
Let me know what you guys think
smiba
What the videos show me is that the OS is smart enough to go into suspend to make sure the user does not lose data, and the EFI/BIOS does not implement this.
This is not the issue and expected behaviour when battery readouts are failing
pws6074
Just the battery on
L7130: 11.97V both sides
F7140 : 11.97V both sides
PPBUS_G3H - 11.73V
smiba
You wont be able to use that one as it's just the unprogrammed chip.
You need to find a donor board (exactly the same board number) from eBay or AliExpress and use the SMC from there.
pws6074
SMC Replaced and works!
However, after a couple minutes the trackpad and keyboard stop work. I tested with another one and still.
Any idea where i can start check for see what happen?
J4813:
PIN 5 = 3.42
PIN 30 = 3.42V
F4800 = 12V both sides, but the schematics say is 16v is that right?
SMC_TPAD_RST_L = 3.42V
U8170:
SMC_S4_WAKESRC_EN = 0
I get just orange light
R5187 SMC_BC_ACOK = 3.4V
U7001 = 3.4V
U7100 PIN 14 SMC_BC_ACOK = 3.4V
pws6074
Yes, i tested and doesn't working.
The keyboard doesn't work too. Don't you think could be another thing?
smiba
No experience with this issue other then cable or trackpad issues. Maybe the USB traces are bad and the device gets disconnected due to too many failed transmissions.
Does it also show this issue when booting into OS X Recovery?
Will the trackpad and keyboard keep working in the boot drive selection? (So while its still in its EFI)
Most likely putting the device in sleep and then waking it will bring the trackpad and keyboard back
