820-4925 Shift key stuck
No-Clean
Clean board, with disconnected keyboard the mac starts up in safe mode and shift key is stuck sometimes enter key doesnt work and or when you press a normal key such as "j" it prints a weird character instead of a "j" same happens with some of the other keys on that same row.
I also tried new trackpad and trackpad cable, same thing.
Also checked and reballed U4820/30 and checked all the pull-up resistors R4850-62 all are good.
Connector looks clean and inside of it is also clean, going nuts here, first time with this issue.
No-Clean
Voltage for pins 1 & 8 of U4850 0v even with keyboard connected and SSD
I will resolder J4813 now and test
In such case, is not Left Shift key issue.
Check if other output of U4850 stays high.
Can you access boot menu?
