820-5509
hello
please need help for 820-5509
i have fan start 1 sec and stop directly
After 30 second same but never boot
i have flash bios same problem
i have 3.3V in big coil
Thanks for you help
with power lab, i have put 12V / 7A and same problem, start 0.165A and stop
i have 2 times up to 0.350A but 1 sec and stop
(for information)
i have check CPU/GPU it's clean, not hot
When fan spins, 5V_S0 is present.
Do you get voltage on other coils (at same time)?
Did you try SMC bypass?
Check other coil no voltage
5V_S0 you know where is it because don't have boardview on this
Don't have check SMC Bypass i can check monday
My error, the fan is powered from 12V_S0.
However, that means S0 rails get enable signal; probably just pulse.
So you should detect pulsing more coils.
i have pulse 0.4V when fan turn and stop on the coil near the 3V
check for SMC BYPASS same problem
on other big coil, i have pulse too but very slow (beetween 0.05V and 0.2V)
When testing in SMC bypass, you should get higher pulse, more easy to detect.
Check diode mode to ground on all coils; compare with good board, if possible.
Also check at USB power rail.
