820-8435 - orientation of clock-chip
jpadie
Hi
can anyone share the orientation of the clock-chip on the 820-8435 board? Or a datasheet for the chip (SLG3NB148CV)?
thanks
Justin
p.s. yes -- took the thing off, stopped for a cup of tea and then realised i didn't make a note. and matching the dot with pin 1 on the boardview just doesn't look right in my memory!
jpadie
top left is an ambiguous concept here John!
but if there is confidence in the dot and confidence in the boardview pin 1 notation then I guess that it's my mind playing tricks on me and the chip is oriented correctly. It look jarringly wrong vis a vis my memory of when I removed it.
As luck would have it I got a very similar board (820-3427-A) in the door 20 minutes ago, so I will cross-fingers and hope that it has a similar component set for RTC and double check against that!
thanks
