A 1707 820-00281
ipetro
Hello. I can't install the system.
Reset PRAM , SMC NOT HELP
ipetro
I tried to turn everything off one by one, and even turned off the display and connected an external one, even moving it to another case the problem remains. I tried internet recovery from the old to the latest axis but the problem remains.
ipetro
I changed another case from a working MacBook and when I try to install the latest version I get this error
ipetro
the system is installed but turns on only in safe mode. in normal mode it cannot pass the critical updates window
ipetro
The MacBook came in for repair because it stopped turning on. After examination, I discovered that the capacitor C3501 exploded. After replacing it, the MacBook turned on in recovery. The system was installed but got stuck on critical updates. And I still don’t understand what exactly is preventing the updates from being installed (downloading is only possible in safe mode)...
ipetro
J4401
DFR_DISP_INT=0,080v
DFR_DISP_RESET_L=0v
J4402
DFR_TOUCH_PANEL_DETECT=0.230v
DFR_TOUCH_LID=1.8V
DFR_TOUCH_RESET_L=1.8v
It is pulled-high by R4481, but is controlled by T1.
Check DFR_TOUCH_LID level too.
Compare with working board.
Did you check if R4481 has correct ohm value?
You may have knocked off component, damaged connectors, broken trace...
