A1278 820-2936-B backlight
hgoncalves
I have an A1278 820-2936-B that has no backlight, and it's breaking all the F9700 fuses.
When I lift up the fuse, I don't see any short on the pads, but when I replace the fuse, it burns again.
Already tried with 2 LCDs.
What shall i do from here? Can you help?
Post diode mode to ground at both sides of D9701; w/ and w/o LCD connected.
Also check if Q9706 is not already shorted S-D.
Why to inject voltage?
There are only 4 caps and U9701.
Very likely the chip is bad.
Inspect LCD connector too, just in case.
However, for pure short, 1-2V should be sufficient to heat the culprit.
hgoncalves
After replacing U9701, LCD connector, C9796, C9020, C9799, turn out to be C9797 :-). It gave a fight, but it turn out to be a success!
Thanks!
