A1398 820-00163 no pp5v_s4
Amber light doesn't mean charging light.
Since 2013 all MacBook get amber light even without battery connected.
"pp3v3"
Do you mean 3V3_S5?
Please post accurate information.
Do you get 3V3_SUS?
Be aware, this board turns on only with 85W charger, if battery (holding some charge) is not connected.
Also use original Magsafe 2 charger.
Post SMC_ADAPTER_EN, PM_BATLOW_L, PCH_DSW_PWRGD, PCH_DSWVRMEN, PM_RSMRST_L, PM_PWRBTN_L and SMC_ONOFF_L levels.
miksonics
SMC_ADAPTER_EN 3.4v
PM_BATLOW_L 0.1
PCH_DSW_PWRGD 3,43v
PCH_DSWVRMEN 3.22v
PM_RSMRST_L 3.29
PM_PWRBTN_L 3.43
SMC_ONOFF_L l 3.43
"PM_BATLOW_L 0.1"
PCH will not start power on sequence in this case.
Usually bad signal because of incorrect charger.
Using 85W original Magsafe 2 charger for sure?
Does it try to turn on if connect a good battery and charger at same time?
miksonics
today i was probing around the PCH, don't know what i touched board came alive but after switch off did not power back on
