A1398 820-3662-a Not charging
TBFix
Hi laptop had liquid spill as is now not seeing/charging the battery. I have reballed the Smc and replaced u7100 as I was not getting SMC_BC_ACOK. Readings on the batt connector are
pins 1-4 = 4.3v
pin 5 = 3.3v
pin 6 = 3.3 - 0.21v
pin 7 .276 - .019v
TBFix
Hi forgot to mention Sda line was short because of U7100 so changed that and sda came back up, (both sda/scl .53) I also had Checked current sensing resistors and continuity to u7100 and was good. R7050 is ok 10k
If battery is not even detected, there is a problem with battery bus.
If you have an o-scope, check for pulses.
If diode mode readings are equals on both lines, then probably bad SMC.
Be aware of battery connector; sometime corrosion underneath can block the bus communication.
TBFix
What should pin 7 read ? as it still read pin 7 .276 - .019v even without battery. I have scope there are pulses on sda line.
Pin 7 must be kept low through R7050; it enables the battery.
You must have pulses on SCL too.
Did you try known good working battery?
TBFix
Scl does not pulse that I can see on scope. I dont have another batter to compare unfortunately. And no donor board of same number to try a different SMC.
ALWAYS use SMC from same donor model.
Sometime board can start with different SMC, but you will get weird issues; only solved by correct SMC.
