A1398 820-3787-A fan spin, no chime
kantuni
Hey folks,
I'm new to electronics, so please forgive any noob questions/mistakes.
I'm trying to repair a 15" MBP Mid 2014. It froze a few times. After the last freeze, I wasn't able to proceed further than the boot launcher. It's running Ventura (OCLP). When I connect the charger (with battery disconnected), I get the green light followed by the orange light, the fan spins, but I there is no chime.
After a cleanup and a thermal paste replacement, I got chime once and everything worked as expected. After a shutdown, the computer was back to the "no chime" state.
Here are the measurements I did so far:
PPBUS_G3H - 12.59V
PP5V_S0 - 5.03V
PP3V3_S0 - 3.32V
PPVCC_S0_CPU - 1.79V
PPVCORE_GPU - 0.89V
P.S. Should I be measuring these with the LCD cable connected?
These voltages look good.
But MLB requires more things to happen, before boots.
Be sure to use 85W Magsafe 2 charger; this board doesn't turn on wiht 45/60W charger, if battery is empty/disconnected.
Doesn't fix on chime only; check Caps Lock LED reaction too.
Check if PLT_RESET_L goes high.
kantuni
Never done that before, but I guess one needs to start somewhere. Do you by any chance have a good .bin file for that model?
