A1425 2012 820-3462, very slow and freeze
VinceLx
Hello,
Another board which looks fine, no visible water damage, but it is very very slow, and finally switches off by itself.
It takes 2 to 3 minutes to boot, then after entering the password another 2 minutes delay, with the beach ball appearing from time to time.
I put this board in a different case which is fine with another board (keyboard and trackpad ok, SSD and its cable ok), with the same result.
No anomalies on the temperature sensors, all below 50 C in HWMonitor.
The original screen was partly damaged, a white vertical flickering strip of 4-5 cm, but I doubt it has an impact? No issue on the screen in the other case.
Where to start here?
Did you try PRAM reset?
Sometime helps doing it 2-3 times.
Did you test w/o battery and w/ known good battery?
Also try USB macOS.
VinceLx
I repeated the PRAM reset several times, did not change the slowness.
With SSD on USB with MacOS: exactly the same, 3 minutes to boot. Then 1 min 30 s to reach the desktop after entering password.
I do all this without battery (the original battery is dead and I don't have spares)
It works normally on the other board, same model, without battery.
