A1466 820-00165-A backlight dont work
lincev
Hello, I have searched the forum for other messages but I have not seen anything similar to my problem.
The equipment turns on and after a second the backlight does not work. With a PRAM reset now the device keeps the backlight until almost the end of the block and it disappears, it gets to the user screen and it still doesn't work. I have done several PRAM resets and I have tried another screen but the same problem..
any ideas? thanks !
Any history available?
Check BKL_EN/PWM when the problem appears.
What is backlight output voltage behavior?
Test starting in safe and also SMC bypass mode.
Backlight always present if keep the machine in boot menu?
lincev
It doesn't work in safe mode at any time. And I have tried three pram resets and neither.
Before at least it worked a few seconds after the pram...
Remove R7704 and run wire from 3V3_S0 to BKL_PWM.
Confirm if you get full backlight; no adjust possible.
Then do PRAM reset 2-3 times.
Remove the wire and put back R7704; still working?
lincev
hello again, I remove R7704 and run wire from C7711 (point 1 PP3V3_S0) to R7704 (point 2 BKL_PWM) but I don't get full backlight, too I try 3 times pram reset
lincev
hi again, sorry but I replace L7701 and D7701 and same problem... I have 8,52v
I try 3 times pram.. arggg board ! ;D thanks
