A1466 820-00165-A PPBUS_G3H no power
hgoncalves
I have an A1466 PPBUS_G3H witout power.
It startd to not charging the battery, and so I replaced the battery. After a while, it stoped working completly. Not even has green light in the charger.
PPBUS_G3H = 0.860V and 0.139 on diode reading.
PP3V42_G3H = 3.4V
SMC_BC_ACOK has 0.070 in diode reading.
U7100 CHGR_DCIN pin has 16V.
Can it be U7100?
No big coils seams to be shorted.
Shall I inject voltage on PPBUS_G3H?
hgoncalves
Hi.
Probably my mistake, but comparing diode readng of PPBUS_G3H with other board, I get 0.545.
After replacing F7140 it powered on once, and then became the same; No green light and no power on.
Already replaced the charging port, but still no power.
00165 should get 0.120-0.150 in diode mode there.
Be sure Q7130 is the correct model.
Post exact C7098 and C7140 voltages.
