It powers on, green/orange light ok
- Missing EDP_BKLT_EN to Q7707
- v1.745 CPU vcore
- USB mouse does light up
I have nothing but the DC in-board, no flex cable, below is the boot patterns.
90% of the time, the fan stops and starts about every 12 seconds and this cycle don't stop and CPU heatsink gets hot.
The other 10%, the fan starts, stops and starts and revs up fast and the CPU heatsink is cool to the touch.
No liquid damage, don't see any corrosion. But a few things to note when I got this board.
- The BIOS seems to have been replaced, same chip type but a different package.
- A jumper wire ran from the D7701 to pin 5 on the backlight driver.
- J8300 connector where the backlight power, is blueish in color on top of the connector.
- Backlight fuse is jumpered - I removed this.
I checked around u6100 and u1900, traces are fine and y1905 connection to u1900 are fine.
u1950 pin 8 has the 3.4v and I did replace it anyways and no corrosion was under it.
I think I went down a rabbit hole.
Any direction or is the CPU/PCH is dead?
Any check else I should check or do?
Thanks
- v1.745 CPU vcore
Thanks
