A1502 820-4924-A no image
hgoncalves
I have an A1502 820-4924-A that has image on external monitor, but no image on internal LCD.
The LCD connector was a little burnt, and so i changed, but without success.
Tried with known good lcd, without success.
I have 5V on pins 28 ~ 30 of J8300
F7700 = 12.59V
I have on U5450:
PIN 3 = 8.8V
PIN 4,5 and 6 = 12,59V
LCDBKLT_EN_L = 8.8V
Can you help?
"I have on U5450:
PIN 3 = 8.8V"
I hope not; pay atention to schematic.
Post diode mode to ground at both pins of D7710; w/ and w/o LCD connected.
"LCDBKLT_EN_L = 8.8V"
BKLT_SD level?
hgoncalves
I didn't realize that PIN 3 of U5450 was PP3V3, but the measure is correct. It has 8.8V (measured with two different multimeters).
Diode readings D7710 :
With LCD =
PIN 1 =1.2V
PIN 2 = 0.9V
Without LCD =
PIN 1 = 1.2V
PIN 2 = 0.9V
LCDBKLT_EN_L = 8.8V (R7702)
BKLT_SD = 5.9V (R7702)
R7702 = 63.3 K ohm
hgoncalves
Sorry..
I'm a dumm. I was measuring at the wrong component...
I don't have the U5450 on my board. I confused it with the Q7700
hgoncalves
Sorry..
On Q7700 I have:
PIN 1 = 12.59V
PIN 2 = 12.59v
PIN 3 = 8.8v
PIN 4 = 12.59V
PIN 5 = 12.59V
PIN 6 = 12.59V
3V3_S4 is 3.3V
On U7700 I have:
PIN 17 = 5.1V
PIN 2 = 5.1V
PIN 21 = 44V
PIN 15 = 5.1V
PIN 16 = 5.1 V
PIN 8 = 5.1V
D7710:
PIN 1= 49V
PIN2 = 8.3V
"D7710:
PIN 1= 49V"
Backlight driver is OK; there is no connection with LEDs strip.
You have a problem with LCD connector, video cable, or display (most likely).
Correct voltage is 40V aprox; when LEDs strip is properly connected.
hgoncalves
I've tried 2 LCD's.
I've replaced the J8300, because mac had no image, and J8300 was a bit burnt on pins 28-30. With other J8300, and with other LCD, it still has no image. I'm testing it with the board alone, and a known good LCD, but still no image.
Can it be a bad solder J8300?
Bad solders, or bad contacts inisde connector.
Do you still have 49V after all changes?
Clean with IPA when you insert the video cable.
hgoncalves
Sorry for the long time to answer.
I've replaced once again the J8300 connector and I still have no image, and 49V on D7710. All the solders are OK, and J8300 well cleaned with IPA.
hgoncalves
In a working A1502, the BL voltage is 48.8V. However, it seams that when I twist the cable, it shows a dim image, I'll try with other LCD.
