A1534 820-00045 no power
hgoncalves
I have an A1534 820-00045 that has no power. The ampmeter stays black, and I have no PPVBUS_E85 nither PPDCIN_E85_SS voltages. Nither seams to be shorted (0.555 on diode reading).
F4700 seams to be ok.
Already tried a known good DCIN cable, with same result.
Can you help?
hgoncalves
Diode readings:
E85_CC1 = 0.554
E85_CC2 = 0.014
I don't have a good board of this model, but it seams that CC2 is shorted. Shall i inject voltage on it, or replace U4700??
hgoncalves
I've replaced U4780 and U4701, but same behavier. Diode on 3V0_AON is 0.329.
I notice now that C4750 PPDCIN_E85_SS seams to be a bit oxidized and corroded. It wasen't shorted, but i removed. Can it be related?
hgoncalves
Replaced again U4700 but same thing.
There are a lot of components with 3V0_AON. Shal I inject some voltage to figure out if something gets hotter?
Voltage injection cannot help here.
CD3215 chip used is good for sure?
Check diode mode to ground on its LDOs.
