A1706 820-00923-A no image
hgoncalves
I have an A1706 820-00923-A with no imagem on the internal display, but it has image on external display.
Already tried known good display and cable, but same result.
DFR_DISP_PWR_EN = 3.4V
EDP_PANEL_PWR_EN = 3.3V
PP5V_S0SW_LCD = 5.1V
PANEL_P5V_EN = 3.3V
PP3V3_S0SW_LCD = 3.3V
PPVOUT_S0_LCDBKLT = 0V, and 0.051 on diode reading
PPVIN_SW_LCDBKLT_SW = 0V and 0.830 on diode reading
Can you help?
hgoncalves
I forgoted it...
Everything seams OK on J8500, except PPVOUT_S0_LCDBKLT that has 0.066 on diode to ground (not sure if it is a normal value cause it is a high voltage line).
Pins 1 and 3 have 0.261 diode to ground
I notice that when reading diode on D8410, when I reverse the multimeter tips, the current flows both ways. Already replaced the diode, and apparently it only happens when soldered to the board. I don't think it should, correct?
0.066 is very low there; was this with LCD connected?
If not, probably bad filter cap on backlight output rail.
