Vogelek23
Hi guys, I've got the computer in title with strange issue - it only turns on after SMC reset (CTRL-ALT-SHIFT + POWER). When turned on, it works perfectly fine, passes AHT and benchmarks, all 4 TBT ports work fine, it does restart correctly every time. Once it is turned off (Shutdown under the OS) it won't back on with power button pressed or lid open - SMC must be reset in order to get it start. I have replaced the power button, reprogrammed EFI, reballed SMC - no luck. Battery is 100% charged now but it happens when battery is low as well. No single sign of spillage anywhere and all sensors are white. What else may cause such problem?
