A1706 with no display on the touchbar
Hi ive got an A1706 820-00239 that originally had a liquid spill back in Feb, i repaired the laptop and its still working :-) apart from the touchbar itself :-( , now first of all i thought maybe the touchbar itself got liquid a s well and just gave up so i replaced the touchbar but no luck , the touchbar dosnt show any signs of life that i can see, question is am i going to be trying to solve a problem im never going to get to the bottom off and messing up a fully working laptop (apart from touchbar) or do you think this is fixable, ive had a look at the schematics and im not too sure where to start or IF too at all, would welcome any feedback or if anyone else has had this issue too
Hi , no signs of corrosion, voltages for j4402 are:
1 = 0v
3=1.3v
5=0v
7=0v
9=1.8v
11=0v
13=0v
15-1.3v
17=0v
19=1.3v
21=0v
then pins:
2=0v
4=1.3v
6=0v
8=1.8v
10=1.4v
12=0v
14=0v
16=0v
18=0v
20=0v
22=5v
and on j4401, pins:
1=0v
3=0.7v
5=0.7v
7=0v
9=0.7v
11=0.7v
13=0v
15=0v
17=0v
19=0v
21=0v
23=0v
25=0v
on the other side pine:
2=0v
4=1.3v
6=1.3v
8=0v
10=1.4v
12=1.8v
14-0v
16=0v
18=3.3v
20=3.3v
22=3.3v
24=0v
26=0v
not sure if that points to anything but im lost :-)
You don't have P1V8_S0SW_DFR present.
I hope you checked with touchbar connected; let me know if true...
"18=3.3v
20=3.3v
22=3.3v"
Means DFR_DISP_PWR_EN and PP3V3_S5_T139 are both present.
In such case, P1V8_S0SW_DFR should be present too, coming out from U4404; any short there?
oooh thanks :-) , just to make thing worse its not an 820-00239 its an 820-00923 which i cant seam to locate boardview or schematics, it looks the the 820-00239 do you know if i can use this one instead ???
