A1707 820-00928 no backlight
hgoncalves
Hi.
I habe an A1707 820-00928 without backlight. It shows a very dark image, but I can see the Apple logo.
External image is OK.
I've already replaced U8400, but with same result.
Can you help?
What is the backlight output voltage?
Check diode mode to ground, if no voltage.
Did you try known good display assembly?
