A1708 820-00840-A no image
hgoncalves
I have an A1708 820-00840-A no image that has no image on internal display, but it has image on external monitor. Alreay tried a known good display and good lcd cable, but same result.
Can you help?
Any history available, liquid sign near LCD connector?
Missing backlight and image too?
Check diode mode to ground on video data lines, especially AUX channel.
hgoncalves
The client says that it stoped working by it self.
I think that I don't have backlight, becausei get 0V on PPVOUT_S0_LCDBKLT (C8500).
I can't identify witch are the video data lines. Can you, please, specify them?
"I can't identify witch are the video data lines"
What about EDP_INT_ lines?
3V3/5V_S0SW_LCD present at least in the first seconds (when chime)?
If yes, DP_INT_HPD goes high at same time?
