A1708 820-00840-A not charging
hgoncalves
I have an A1708 820-00840-A that works fine, but does no charge the battery (only works with charger connected), and down't know where to start.
Already tried with a known good battery.
The battery is recognized but stays at 0%.
U7000 looks normal.
R5381 = 1.98 kohm
R5380 = 1.99 kohm
SMBUS_SMC_5_G3H_SCL = 3.4V
SMBUS_SMC_5_G3H_SDA = 3.4V
PPBUS_G3H w/o battery 13V
Can you help?
Diode mode to ground at SCL/SDA lines?
R6950 is good?
Battery big screw correctly tighten?
Data cable connected OK?
Post PPBUS_G3H and 3V42_G3H levels with battery only.
hgoncalves
R6950 = 9.9 kohm
Diode:
SMBUS_SMC_5_G3H_SCL = 0.474V
SMBUS_SMC_5_G3H_SDA = 0.474V
PPBUS_G3H =11,15V
I can't find 3V42_G3H. Is it right?
So original battery also works in other similar machine?
Trigger SMC_ONOFF_L and check for drop pulse at PM_PWRBTN_L (only battery).
hgoncalves
Tks.
After all, it seams that the problem was the data cable connecting the battery to the board, that had some kind of problem. With a new cable, the problem stoped.
Tks!
