it-solve
It turns on and works fine for a while, but often when it starts or awakes from a long-term not usage turns on with a question mark. Same when used for an extended period of time.
Previous liquid damage around U3890/5 doesn't seem to be related to SSD lines. Also, some around R3773 and U3700 corner.
Tested with two good known SSDs, reinstalled still an intermittent issue. Cant measure with a board outside of the case when an issue occurs hence omitted some measurements.
J8600 - When Problem Occurs
4 - 0.24V
5 - 0.003V - SSD_PWR_EN_CONN_L
6 - 1.78V - SSD_BOOT_CONN_L
7 -
8 - 0V
9 - 3.4V
10 - 3.2V
11 -
12 -
13 - 3.2V
Looking at @tipoti trouble when it's working, measurements seem to be the same as mine when not working.
Cleaned the connector multiple times and inspected under a scope. No damage.
4 - 0.24V
7 -
8 - 0V
9 - 3.4V
10 - 3.2V
11 -
12 -
13 - 3.2V
