hgoncalves
I have an A1708 820-00875-A with that has no power.
It had no backlight and PPVOUT_S0_LCDBKLT was shorted, and i replaced C8467 and C8463 because they were burnt.
After replacing those, the mac didn't power on again. It only pulls 5V from ampmeter.
I notice that one of the charging port was rebooting, and when measured, on U3200 (the on that was rebooting), I get, on diode mode, 0V on USBC_XB_CC1 and on USBC_XB_CC2.
After replacing U3200, CC1/2 gets 0.600V on diode reading, but still no power, and a black ampmeter on that port.
PP20V_USBC_XB_VBUS_F has 0V on diode reading and 0.13 ohm to ground but because it is a high voltage line, i'm not sure if those readings are ok.
F3010 seams to be ok.
Can you help?
Can you help?
