A1708 EMC 3164... works great until I try to shut down
nkycomputers
Customers device had liquid damage... no wifi developed into no power... cleaned visible damage and sent thru ultrasonic cleaner
Laptop now powers on wifi works charges battery etc... Im having trouble locating any malfunctions... however
When I choose shutdown the macbook just restarts... after about 5 seconds.. works fine no lag but will not shutdown unless...
If I hold the power button it will shutdown
Thank you very much for this resource and any assistance you can provide
nkycomputers
Sorry let me clarify that... it powers on and off with power button (does not restart) ... but if I shut down thru OS it shuts down then powers right back on
nkycomputers
all tests passed in Apple Diagnostics... I feel this must be a software issue... only reason I suspect something else... is it definitely was water damaged
nkycomputers
**Update** its not a software issue.. it restarts with shutdown command from any OS... cannot find any issues other than the restart upon shutdown... it boots, posts and runs fine... charges and everything... I cannot find any non functioning components... yet it still restarts on shutdown unless I physically hold the power button down
Did you find corrosion on mentioned area???
Ultrasonic cleaner cannot rebuild a broken trace.
Check AP_DEV_WAKE, AP_PCIE_WAKE_L and BT_WAKE_L voltage.
